Where in CA are you located? Do you have a small block or big block toploader?
This can get kind of complicated because you could also go the clutch cable or hydraulic clutch route. With either of these, you wont have to worry about any of the clutch linkage, which frees up a lot of room for headers.
The clutch and clutch fork depend on what flywheel you are running. The flywheel depends on what bell housing you are running.
With a hydraulic clutch, the bell housing (and everything) doesnt really matter. You can get slave cylinders that either push or pull the clutch. Plus, you can mount it to what ever side of the clutch fork you want (to achieve pushing or pulling the fork). You would need to get a master cylinder, hydraulic line/tubing, fittings, a slave cylinder, and a brakcet to mount the slave cylinder. You can source the parts yourself, or perhaps modify a kit for an early Mustang. This is kind of attractive because it can be modified to fit any engine/trans/flywheel/clutch combo.
The bell housing matters for a clutch cable. The cable pulls the clutch fork toward the engine to operate the clutch. SROD bell housings (found in early 80's mustangs with a "4 speed") will mate up a 6 bolt SBF and a toploader, and have provisions for a clutch cable. This setup would allow you to run a bigger flywheel and clutch than early cars. This setup may not be worth the hassle if you don't have enough room between the top of your clutch pedal and the cowl. The plus side is that most of the parts were used in Fox mustangs, so they are readily available at your local parts store. There are some "specialty" parts needed that are produced by a couple different sources (clutch pedal quadrant, firewall cable stop). I did this conversion on my 68 Ranchero and went with Mustang Steve's items. They were designed for an early mustang, but not much modification was needed to get them to work in the Ranchero. For more info on this conversion, check out
http://www.mustangsteve.com/cable.html.
Lastly, if you go with the clutch cable, I have the bell housing you need.
