I HAVE A LEAN (I THINK) BACKFIRE UNDER A LOAD. I DECIDED TO SCAN THE CODES AND THE SCANNER POINTED OUT THAT MY #7 INJECTOR IS BAD. HAVING NEVER CHANGED INJECTORS I WAS WONDERING IF ALL INJECTORS NEEDED TO BE REPLACED OR CAN I JUST REPLACE THE BAD ONE?
WHO HAS THE BEST PRICE ON STOCK INJECTORS?
MAYBE ONE OF YOU GUYS HAS AN INJECTOR OR A SET AT A GOOD PRICE. THANKS
[email protected]
you can change just the one, but make sure first its not the wiring to the injector or something like that. get a little fuel injector tester, its a little fuse like thing that you plug in to where the injector is and it will lightup if its getting a signal.
If its a 19lb injector, you can get them from any 5.0 at a wrecking yard.
