I just fired up my 302 after a short block rebuild and it was smoking more than I like. I used chrome moly rings and hyper pistons instead of cast and have always heard that they take a long time to seal. I've never used moly rings before so I don't know. Could this be why it's smoking?
If that's not it I guess I'll have to pull the heads off and give them a valve job. They only had around 30K miles on them though.
I would give it a while before you get excited.the rings may need a little time to seat.I always use straight 30 wt oil on a fresh rebuild.The heads should be ok with only 30k on them if your worried about valve seals leaking.
Bob
That makes me feel better. I've only run it for a few minutes; like 15. I'm doing a whole car rebuild on a '79 pacecar and want to get it painted next month. If I have to pull the heads and intake I'll have to hold off on the paint. I wouldn't want to screw up a fresh paint job by dropping a head on it!
I've been slightly concerned about valve train geometry. My heads are DO0E 351 heads shaved .040. They were on a standard flat tappet 302 with fully adjustable valve train, studs and guide plates. Originally I bought hardened pushrods from FMS that were designed for 351 heads on a 302 but the .040 thing worried me as far as guide and seal wear. I had a great deal of oil use in my old engine but I chalked it up to a crappy short block rebuild. It used a quart every 400 miles from the day I installed it and even before I put these heads on it.
I useed a set of molly rings once and have always said, NEVER AGAIN. They never seat. I was constantly changing fouled plugs......some guys like em.......I think they should be against the law.....hope your work bettter than mine.
Good Luck,
LJ
With moly rings it's important that the cylinders are honed for there use. I think a lot of people have trouble with seating because they have there machine work done anticipating cast rings.
I believe moly rings require less lubrication so they work better with a finer cylinder hone.
I had the machine shop do the short block so I *hope* they knew what they were doing.
