I've seen various discussions concerning serpentine use on early mustangs, however, I've not seen a clear answer on whether a time cover change is feasible.
I've got an early 5..L HO FI motor I with to install... I understand that the "FOX Body" pan needs to be changed, along with the oil pump pickup, but by doing so, you lose the use of an oil dipstick in the side of the block.
I have a 76 Granada timing cover, that has the front dipstick, and can easily install it.... BUT will the waterpump and serpentine components work with this timing cover??
Any info would be greatly appreciated..
Mitch
Mitch
