building up '51 f1,have had this issue in other truck/cars,forgot how solved it.Start up run/drive to store or just loop around n come back,even just run sittng in driveway,shut it off n try restarting.If Try right away it starts with maybe some drag or cranks like battery dying.Gone Thru everything,battery at nealy 13.45 on meter,no wiring hot like bad connection.This is mid/late 80s rebuilt engine,single wire altinater,silenoid properly wired.Have seen diagrams with ballist resistor in 2 type layouts,not sure if that's whats missing.BIG PAUSE-OWNER INPUT>O.K.Thoughts were given to installing other standard starter had on shelf;that was the one too big so went to small starter to fit behind-away from-exaust.Am working in shield,still take input on restart issue,thanks all.
