1 - 20 of 47 Posts
Here is my new 520 cubic inch stroker 460 Ford engine.
SPECS
0.30 over bore 13.5 to 1 JE pistons custom made for TFS A-460 chambers.
SCAT 9000 4.300 stroke crank
SCAT 6.800 H Beam Rods
TFS A-460 heads 340 CC
TFS A-460 4-V intake with spacer to port entry porting / blending to match 1150 CFM 4500 Holley
BRE custom order 1150 CFM Holley 4500 HP
.725 lift 275 @ 0.50 Comp Cam Solid Roller
Crane Gold Racer Roller Rockers
Jomar Rocker Stud Girdles
Meziere Electric Water Pump 55 GPM
Fabricated Valve Covers
Romac Balancer
Riechard Racing Billet Timing Pointer
Moroso Stage II Drag Racing Oil Pan
Ford SVO Oil Pump and Shaft
RollMaster Timing Chain
MSD Pro Billet Distributor
1966 Comet Capri 520 CID
1966 Galaxie 500 XL 428 CID
2000 Excursion LTD 444 CID
<font size=-1>[ This Message was edited by: DynoTom on 5/17/06 1:51pm ]</font>
<font size=-1>[ This Message was edited by: DynoTom on 5/21/06 11:16am ]</font>
Here is the car.....It's still going to look stock-ish.....No stickers, stock glass windows,carpet inside,factory door panels, factory type bucket seats,all steel body panels and bumpers.....
<font size=-1>[ This Message was edited by: DynoTom on 5/17/06 2:33pm ]</font>
Thanks, Yes it was a 289 when I picked the car up but, I really wanted a "all motor" Big Block in her.....We are not tuning the engine for "all out" power we are tuning it for the street use it will see....I would never want a "track only" car.....
A-460 heads BBC exhaust port.....I'm sure it will be a powerfull engine bordering on scary / insane ...
What was the reasion going with the T-400??
Tim
Discussion Starter · #13 ·
Tim
Yea, it was really just asking around and researching what guys were running to see what they said?
I found the trans that could take the most abuse for the longest time was a TH 400...
The engine was also designed to last longer than most engines in this HP class....I could make a lot more power with a bigger cam and 557 cubes ( both of those things would have not cost me any more ) but, we wanted a street motor that would be longer lasting and easy on parts....
The dyno pulls we make will reveal the best tune it needs and I will also chassis dyno the car in the future.
Alan, I did think about going with this type of engine for a Galaxie but, in the end I thought the Comet would be neat and get more results with it's lighter weight.....
Hmmm. I came to the same conclusion so I now have a 67 Fairlane I am working on. I still have the Galaxie though.
[/quote]
Discussion Starter · #15 ·
Yep, I love your Galaxie Alan!
I still have my 66 Galaxie too, I really like the new engine combo I have in it, I'm installing a new fuel system as we speak.....I also added MSD 6 AL, aluminum Radiator, Electric Fans and new wheels for it.
Welcome back Tom. I was just driving back to office thinking about you and Cook and how this site has sucked without you.
Go Pack. What do you think about A.J. Hawk as their first pick? Bob.
Welcome back DT. We've been waitin' to hear from ya. Sounds like a pretty potent package you put together there. Lookin' forward to hearing/seeing it sometime. Give the fellas at the other place a jingle.
Welcome back DT!
Did'nt the Comet have a sweet 289? I still have a vid of it on my HD.
That thing is going to be a freaking MONSTER!
1 - 20 of 47 Posts
