Used 83-85 mustang gt aluminum valve covers $80 shipped
used 87-93 mustang stock headers. Just been painted blk $75 shipped
used roller lifters,tray and hold downs $60 shipped
used 289-302 edelbrock performer intake. Part # 2121. Need cleaning $120 shipped
used omega/scorpion 1.72 ped mount roller rockers with hardware $150 ship
used ford sfi balancer c351 $200 shipped
used proform 1.6 ped mount roller with hardware $150 shipped
used eagle 5.40 rods,2.10 rod with arp 2000 bolts. they have about 2000 miles $325 shipped
used cobra 1.7 rocker $175 shipped
USED COMP CAMS HR/SR CAM GRIND # 3317F/3318F-R110 242/[email protected],576/600 LIFT,110LS. THIS CAM CAN BE USED WITH HYD OR SOLID ROLLER LIFTERS $225 SHIPPED.
USED COMP PRO MAGUM 1.6X3/8 WITH LOCKS $175. THEY ARE IN GOOD CONDITION SHIPPED
USED SB FORD TRICK FLOW TWISTED WEDGE R HEADS. 206CC INTAKE RUNNERS,2.08/160 VALVES, 720 LIFT SOLID ROLLER SPRINGS,61CC CHAMBERS.THESE HEADS ARE LIKE NEW WITH DYNO TIME. THEY WERE ABOUT $2000 WITH SOLID ROLLER SPRINGS, SELLING $1650 SHIPPED, OR TRADE FOR 79 PACE CAR,80-81COBRA OR 82 GT
USED SB FORD COMP CAM SOLID ROLLER CAM HAS 55MM CAM BEARING ON THE FIRST FOUR JOURNAL AND A 50MM REAR CAM BEARING, , LIFT IS .867 INTAKE AND .791 WITH A 1.7 RATION ROCKER, EXHAUST, DURATION AT .050 IS 288 / 278 DEGREES, LOBE SEPERATION IS 110 DEGREES $250
NEW COMP CAM SOLID ROLLER CAM FW , HAS 55MM CAM BEARING ON THE FIRST FOUR JOURNAL AND A 50MM REAR CAM BEARING, , LIFT IS ..768 INTAKE AND .707 WITH A 1.6 RATION ROCKER, EXHAUST, DURATION AT .050 IS 287 / 300 DEGREES, LOBE SEPERATION IS 114 $325
USED COMP CAMS .726 INTAKE AND .693 WITH A 1.65 RATION ROCKER, EXHAUST, DURATION AT .050 IS 250 / 272DEGREES, LOBE SEPERATION IS 112 DEGREES, $250 SHIPPED
USED COMP CAMS LIFT IS .704INTAKE AND .672 WITH A 1.6 RATION ROCKER, EXHAUST, DURATION AT .050 IS 254 / 272 DEGREES, LOBE SEPERATION IS 112 DEGREES $250 SHIPPED
ANDERSON SB ROLLER 260/268 at .050, 624/634,108
GT40 351W LOWER INTAKE $400 SHIPPED
COMP CAMS SOLID ROLLER LIFTER $250 SHIPPED
CROWER HIPO ROLLER LIFTERS $ 375 SHIPPED
FORD C4 26 SPLINE. ROLLER DRUM,REAR PLANET GEARS &HUB .ALL THE PARTS HAVE BEEN SET UP FOR ROLLER BEARNINGS. THE ONLY USED PART IS THE REAR HUB BUT IT HAS NEW ROLLER BEARNING $175 SHIPPED
New sb ford romac 50oz damper. This is a alum/steel damper. You do not need spacer with this balancer $250 shipped
