howdie I'm new to this site and from what I've read I have found the right one. I have a 58 fairlane 500 four door with a 332 interceptor and only 56k original miles. I would like to swap it over to front disc brakes and possible pull the original engine and drop in somthing newer. I would like to do this as a Bolt On because of the great shape this car is in just in case I want to sell it later as an original. anyone out there can help me out. Thanks.
Not too sure on the brakes. I did a '57 Ranchero but it was over 20 years ago. You can bolt in a variety of FE engines from a 332 which you already have, to a 428 which only needs a different flywheel. I have seen swap mounts for 460's as well, gotta do some searching.
