If it helps, for future reference, 1965-69 full-size Fords and 65-67 full-size Mercury's only had the 4-speed Toploader mated with the Z-code 390, P-code 390 (in '65), Y-code 390-2V (1967-later), M-code 410, Q-code 428, P-code 428 ('66-67, law enforcement only) and R/W-code 427s. All had the big-input 1-3/8" 31-spline except the 390 which had the smaller input 1-1/16" 28-spline.
There were no 289, 352, 390-2V or inline 6s built at the factory with 4-speed Toploaders.
If you want to run a 289/302 with a 4-speed toploader in a '67 Custom, among things you'd want to look at the tailhousing and see what works. Not sure if the three speed tailhousing will bolt up or not. David Kee Toploader will know. Also, look closely at the clutch linkage. If 3-speed clutch linkage for a column shift is the same as 4-speed floor shift, then no problem. Otherwise you'll need to hunt down parts. But beware there weren't many full-size Fords or Mercury's with 4-speeds in those years and finding parts can be a real bear.
If it were me, I'd get out the Master Parts Catalog to look at the original assembly diagram and associated parts. That way I'd know for sure what parts are shared between column shift, floor shift, 3-speeds, 4-speeds, tailhousings and so on. It's all in there in the MPC.
