1 - 20 of 25 Posts
One of Ford's not so good ideas was the addition of an offset shaft on the front pivot of the lower control arm on 1960-1964 Galaxies and Mercury Marauders. The offset shaft actually moved as the car was traveling and encountered road irregularities. The camber, caster and toe would all change dynamically as the car was moving. Ford did this to give the car a nice plush ride, and it worked well at slower speeds.
Once vehicle speed was increased, the cars felt like wet noodles. Ford knew this fact and tied the lower pivots together with a bolt on bar on taxi cabs, police cars and any car that would see extreme road conditions. I have seen a couple of these bars on Galaxies over the years. There were also some straight lower pivot shafts that would not move and change the front end settings, but they are not readily available. I have also read about people welding the shaft in position, but that makes removal of the lower A-arm more difficult later.
I fixed the "wet noodle" feel on my road race '64 Galaxie by bolting on a simple aluminum radius rod and a couple of brackets to the offset shaft on each side of the car and effectively tying them together so the A-arms cannot move.
Here is the offset shaft I am talking about. One side of the shaft that bolts to the frame is offset about 5/8" from the side that bolts to the lower A-arm:
I built a small bracket out of 3/16" plate that will bolt to the offset shaft. The bracket has a 5/8" hole to slide over the offset shaft, and a 5/8" grade 8 bolt welded to it. The bracket also has a slight bend to allow the radius rod to bolt on straight:
The original nut that holds the A-arm to the offset shaft is used to hold the bracket on:
The aluminum radius rod is 19" long and has left and right hand thread male rod ends on each end. This is a common circle track item and can be bought from Speedway Motors:
The radius rod is adjusted for length and is now bolted to the "stud" on each of the brackets bolted to each of the offset shafts. A self locking nut is used to secure the rod:
The radius rod now will effectively tie the two offset shafts together so that they cannot move. The feeling of the car at speed is nice and stable with no movement at all:
FM Tech Exchange contributor Dazecars informed me that he believes Ford started installing the offset shafts in 1963. I merely included the years 1960-1964 becuase I have seen the offset shafts installed on a 1961 and a 1962 Galaxie, though I don't know if they were factory installed. Can anyone tell us for sure what year Ford started installing them?
FORD- 63/64
MERC- 61/64
They were not used on all models. POLICE and HP used a 1962 lower arm.
There are several style kits to stabilize the control arms although yours would look bitchen sitting in front of a 7-QT oil pan... :cool:
FORD- 63/64
MERC- 61/64
That makes sense. Ford thought it was an improvement so if it was available on the Merc cars in 61 and 62 I can see how it ended up on some Galaxies, probably as a dealer install..... I am just glad my 62 did not have them :) :)
This only pertains Galaxies. All 63 and 64's had the offset shafts even the Hi-Po cars and police cars. Only the Light Weight Galaxie drag cars did not have them. They would not fit on 62 and earlier cars because the frames were not made for them the hole for the lower control arm bolt was too small. The bar that Donahue sells is a copy of one made by Cure-Ride. There were other bars made that did the same thing. The Moog kit was too bars that bolted to the front crossmember with rubber bushings and to the lower control arm bolts. Mark the director of FGCoA sells a kit to replace the off set shaft with a straight bolt. It is a copy of a kit made by a So-Cal Galaxies member.
Partially correct.
There is a difference in the 60/62 and 63/64 frames whereas the earlier control arms will not fit the later FORD. I remember a thread some while ago regarding this and completely forgot about it. Your post shook a few cobwebs loose.
There were two control arms released for the 63/64 regarding this feature.
63/64 A (except P/I and Taxicab)
R.H. C3AZ 3078-D
L.H. C3AZ 3079-D (CORRECTED)
63/64 A (P/I and Taxicab)
R.H. C3AZ 3078-E
L.H. C3AZ 3079-E
From- 60/64 FORD MPC
(The PN Suffix E control arms has no provision for the off-set bushings.)
Now this being said, one would only assume the feature was not used on lightweights but what about the 64 R-CODES released for the street? I have a 62/63 LIGHTWEIGHT SERVICE BULLETIN here somewheres, and I remember it covering body panels but am unsure of the suspension.
What we need is owners here with 62 and 63/64 406/427 and Police to look under their cars and post here what they find.
I would think the control arms without the feature would be hard to find now (and most likely then) and why the correction kit(s) are so popular.
I think JCAllison mentioned his PI did not have the offset shafts. Rare Parts sells ones like Ford made and are listed for Police and Taxi. I just installed ones like these that I bought from another Fordmuscle member a couple years ago. I'm still waiting for the machine work on the engine so I haven't driven with them yet.
http://ecomserv.bytedesigns.com/ez/retail_order.asp
<table bgcolor="white" border="1" cellpadding="2" width="100%"><tbody><tr class="row1"><td>18021 </td><td>CRANK REPLACEMENT, Lower Inner, HIGH PERFORMANCE CRANK REPLACEMENT KIT and POLICE/TAXI</td><td align="right">233.71</td><input name="core1" value="0.00" type="hidden"><input name="tkdiscount1" value="" type="hidden"><input name="Price1" value="233.71" type="hidden"><td align="right">
</td></tr></tbody></table>
KULTULZ. The part number you gave for the left sides are the same number. ? These were heavy duty parts and did have the offset shafts. '62 and earlier frames had a different front crossmember and did not have the threaded insert for the "Big" hollow bolt that the offset shaft used.
As far as that kit from Rare Parts goes, Ford never offered that kit. If I'm wrong please share the Ford part number. Also my Novenber '62 LA built '63 G code 406 has offset shafts and a friend who has a 63 1/2 R code 427 built in May of 63 at the Twin Cities plant has them. Early 63 Light Weights were rebodied on '62 frames.
KULTULZ.
The part number you gave for the left sides are the same number?
That is referred to as having your butt up your posterior. I corrected it.
I don't believe that FORD offered a correction kit. The alternate controls arms were available for service.
I have a 62/63 Light Weight Bulletin here buried. Let me see if I can find it.
Hey Guys, throwing my two cents in here. As has been stated 62 frames and suspension are totally differnent animals from there 63-64 counterparts. Its also correct that some lightweights didn't have the offset shafts due to the fact that they were rebodied 62's. This was done on the early cars and the later 63 lightweights should all have the offset shafts. I'm currently working on a 62 Mercury S-55 with a factory G code 406. This car has no offset shafts with a bracket rivited onto the front of the lower a arm to accept a standard bushing and bolt. The 63 R code I'm also working on has the offset shafts. Since 63 and 64 share frames they would both have offset shafts no matter what engine they were equipped with since the front crossmember is threaded to accept them. There also is no difference between standard and Police/HP suspension in 63-64 except for springs and, steering stops for 15 inch wheels.
This thing is really cool. Who makes one of these? I guess I could do it myself but I would like to buy one. The links are dead.
I've been reading this thread a few more times, and studying the pictures, trying to decide if I can make my own or buy the kit, but problem is that I think the rod will either touch the sway bar or get very close to it.
The pictures don't show the sway bar in place, so I can't figure out how close it will be.
1 - 20 of 25 Posts
