21 - 25 of 25 Posts
Discussion Starter #21
I've been reading this thread a few more times, and studying the pictures, trying to decide if I can make my own or buy the kit, but problem is that I think the rod will either touch the sway bar or get very close to it.
The pictures don't show the sway bar in place, so I can't figure out how close it will be.
It will clear the stock sway bar. It will not clear a 460 engine without spacing the bar a tad.
Oh OK, it looks like it might be pretty close to either the sway bar or pan, as it looks like it will run between them.
Mine is 427, but it has a Canton Pan fitted. Do you know the clearance between the pan and sway bar so I can compare? My Canton is only stepped out wider at the bottom.
Will you ship to Australia, and would you know of the shipping costs?
Cheers Dan.
I have just got a 64 Galaxie and am confused regarding
parts for the lower control arm.
I see listed this
Lower Control Arm Inner Shaft Kit at C and G
but Donahue describes a Lower Arm Control Offset Shaft.
What is the difference?
cheers
John
Australia
Bringing this old thread back to life😀
Just wanted to show my simple solution to the problem. Total cost was about 50$.
165474
Will get back with a short review when I have put some miles on it.
21 - 25 of 25 Posts
