I recently became the proud owner of a 1960 Falcon with 144 ci straight 6. From what I was told, it has been sitting in a shed/barn since 1994. The engine wants to run but doesn't seem to be getting any gas. The shop replaced the gas tank, fuel lines, sending unit, and fuel pump, as well as a quick carb rebuild. It appears to have gas and will start if gas is added to the bowl.
I pulled the fuel line off the carb and the fuel pump is not pushing any fuel. I had a discussion with a guy about possibly needing to prime the pump, does any one have any suggestions?
