Hey everyone, unfortunately my 62's engine had issues i posted about you guys were correct. So it's being rebuilt next month, who needs money anyway. I need to put new locks in the doors and ignition. Panels are already off but I cannot get the clip off to remove the door locks, any tips? Also when I attempt to remove the ignition lock as directed I put it in the accessory position and no dash lights go on. When I insert the paper clip and go past the accessory position the dash lights go on but the lock will not release. Thanks for any help.
Use plyers to pull the door lock clips off if you can't get enough grip. If the ignition lock will not pull out your not going far enough around. Once the lock goes past the stop pull the paper clip.
