So I just found out that the rear passenger axle is jacked up so Iam in need of a good set to replace both sides so the worped one measures 32 1/4 long. where can I get a good set of axles for it.. Thanks guys
Moser and others can sell you new ones. There is probably a couple options right in the Summit Catalog. For 1962 the stock passenger car axles were 28 spline.
There are 2 different bearing sizes based upon the application:
Big bearing for wagon/police/taxi/hipo.
Small bearing for everything else.
If you can't find a donor set, I'd also give Yukon Gear and Axle a call at 1-888-905-5044 for price comparison. Don't forget to include bearings, retainers, seals, studs and shipping in your final cost from any new or used source.
