Nice. Wow, he has a lot of driveshaft boom in the straightaway. Time for a custom unit with higher modulus I'd say. That boom will take-out your bushings and bearings in fairly short order. Nice to see the old iron showing the 'kids' a thing or two.
:tup:
David PSIG, what do you mean by "driveshaft boom"? What does it sound like? Are you referring to some of the noise at about 5:13, what seems to be on a straightaway? What causes driveshaft boom?
Exactly. Notice how it cuts-in rather suddenly as it reaches it's harmonic frequency, and then cuts back-out just as suddenly at RPMs drop through the frequency. Driveshaft boom is where the shaft actually begins to get waves in it due to both hitting a critical frequency, and the stiffness (or lack of it) in the driveshaft. Look at it like it was made from stiff rubber. The material has a certain modulus (stiffness) and the diameter and length affect the frequency. You can change one or all three to change or eliminate the boom.
Note for comparison - that a worn transmission output shaft bushing, bad mount, cocked U-joint, etc. give a similar effect, but also has far more vibration with it. If you hear boom cut-in at 'normal' highway speeds, and it blurs vision out your rear-view, then it's one of those. The whole shaft runs and bends (whips) off-center. With boom the driveshaft gets a twisted S-curve or wave in it, and though there is some vibration, you don't feel like it will take the car apart. Similar but different.
It was kind of cool seeing the big old bad Ford putting a hurting on some of those more modern "race" cars. Especially the yellow Porshe. I bet he was like, "WTF!?"
