Can anyone verify whether or not you can put 63 model fenders on a 62 model car. I will be needing a hood and grill, so I thought about just using the 63 front parts if they will work. I was not sure if the lines and the mounting holes were the same. Any help would be greatly appreciated.
I think the light bezel is different on a 62. It shows more when you look at it from the side. Im not 100% sure but thats wut i saw on ebay and google
the trim holes won;t be anything the same, but you could weld up the 63;s.
basicly you would have to change the headlight surrounds, ,grille, upper/lower grille moulding & drill holes for the side spears to match the 62
Leethal72, I'm not sure. I own a 62 and have not had that issue. I know where you can find the answer though! It's a salvage yard called Twin Cedars, located in Corydon, IN. His name is Carol. Hope this helps... He also has a couple of 62's in good condition, I took a back window glass out of one, it had then, two good fenders, hood and grill. Also check with the boys at AutoKrafters.com Enjoy!
TWIN CEDAR AUTO PARTS
HOURS 9-5 - CLOSED SUNDAYS & WEDNESDAYS. AFTERNOON
R.R. 1 - CORYDON, INDIANA 47112
CARROLL STINSON, Mgr. - PHONE 270-738-3398
http://www.autokrafters.com/
