Hey Fellow Falconeers, need some advice on my T-5 w/ S10 tail section tranny swap hiccup. The ford Mechanical speedometer will Not go in, without removing a major section of the tranmission bracing. I have already removed the top section of this thick hump bracing to accommodate the T-5 . I have read before this is an important bracing to the flooring for Rigidity ? Any suggestions for getting the Mechanical Speedometer into place (What have others done ) Or to remove the bracing all together ? and if so , what after market bracing to replace it with for The rigidity ? Really Appreciate any and All suggestions, Ty & Stay Fordified !
