Can someone please post pictures or email ([email protected]) of where the hood pin bolts are mounted on your radiator support? I'm putting on my teardrop today and trying to figure out the best place/location. Currently the bumper stops looks like a good level area, but don't think it a good idea to remove them?
Kevin
Most likely the hood bumper spot is the best. If you have a quality pin kit, the pins will be adjustable in height once installed. You would get your hood tip alignment with these and also be sure the fixed bumpers on the fender lips are there and in good condition.
The pins have to be on a true vertical or it may become hard to close/open the hood. If not satisfied, the adjustable hood supports can be reinstalled slightly away from the pins.
