Hi! New to forum, and needing some help. I am attempting a frankenstien of sorts: trying to put a 64 model 289 5 bolt into an 85 F150 2WD C-6. Is this possible? Will the early 60's 5 bolt bell bolt up to the 85 C-6?
the C6 doesn't have a removeable bellhousing, you can get a bellhousing to fit the 5 bolt engine and mate with a C4.
Thanks for the reply. I have a C-4 available, so maybe no big deal. Is the crossmember and shift linkage the same from the C6 to the C4? Will the tailshafts be same length? Any info is welcome!
