i was just seeing if anyone had any information on a drum to disk conversion on the front of these trucks.
being that its leaf springs suspension in front, i assume there isnt another year F series that are compatible.
but im hoping :/
any info will be much appreciated thanks guys
We also have done the 4th gen F-100 manual disc swap on my son's '64 using GM calipers. We used a different but similar bracket setup. The conversion is inexpensive, simple and very effective.
:tup:
Discussion Starter #4
awesome exactly what i need! thanks a lot guys
how about brake booster and master cylinder?
any certain aplications dont work or work best?
theres a lot of fire wall space, any truck booster may work as long as it clears the hood.
im ofcourse going dual master cylinder
thanks again
I'm not the answer guy on 4G F-100s, but stock '70s and '80s PB stuff will bolt-up if converting from manual to power. Same if staying manual, which is what we did as we didn't want to change-out the whole pedal assembly and such, and we weren't towing houses, so power brakes were not at all necessary. A fresh 1970s $25 master, a P-valve, and some brake line and fittings did it all. We kept the old brake pressure switch on the front T-block so no extra wiring and works great. There are lots of articles and posts about it with lots of ideas to do the similar things, so do a search and pick your path.
:tup:
any certain applications don't work or work best?
im of course going dual master cylinder
thanks again
I tend to leave my stuff manual brakes with no booster, and I've used a master cylinder for an early 70s Ford truck with front discs and manual brakes. Think it was 72 3/4 ton that had the option. You'll also need a suitable proportioning valve & brake lines.
If you must have power brakes, I'm sure any Ford Truck setup would be easy to adapt.
