I'm restoring a 64 Fairlane, and completely redoing the front end. I Have the front end stripped down to nothing. We've managed to get the old ball joints out of the lower control arms. My question is how do they need to be reinstalled. The old ones were riveted around the ball joint, and had a 4 inch flange. The flange was bolted to the control arm with the bolts for the strut rods, but they were also spot welded in 4 spots. When putting the new ones in, will the bolts that replace the rivets, and the bolts for the strut rod be sufficient? Or should I weld the flanges back in. They were a pain to get out, and don't look forward to ever having to do it again.
TIA
GGroth
I simply added the bolts to the rivet holes, and then bolted in the strut rod. I rebuilt my Fairlane and a few Mustangs in that manner with no durability problems.
I got mine from Espo springs, http://www.espo.com. They don't have their prices listed because of volatility in the pricing of the parts (what they told me), but they had everything I needed. I ordered everything for the front and back of my '64, minus the center link and pitman arm, and it came in around a grand (front/rear springs, upper/lower control arm bushings/shafts - the bushings/shafts for the uppers were expensive - but were expensive everywhere I looked, upper/lower ball joints, inner/outer tie rod ends, strut rod bushings, idler arm bushings, shackles, U-bolts, everything). Real nice to deal with, and they shipped pretty fast too.
Cheers,
GGroth
I ordered a complete front-end rebuild kit from Performance Suspension (PST). They will probably sell the lower ball joint separately.
I ended up paying about 450.00 for upper control arm kits, lower control arm bushings, upper and lower ball joints and idler arm.
At this time forget trying to find a manual steer drag link for 64-65 fairlanes made after 3-2-64.
I have a brand new pair of outer tie rod ends for 62-65 manual steer car if you are interested.
96 Ford F350 PSD CC DRW
97 Ford Taurus
64 Fairlaine 500 rust bucket/future Tbolt clone with 514 BBF
<font size=-1>[ This Message was edited by: Just Strokin on 5/22/02 9:37am ]</font>
