Hello to all,
I'm new here so I have a question about brakes. I converted he front brakes from drums to disc. I purchased a new master cylinder. No my question is on the brake light pressure switch that goes in to old master cylinder. The new dual bowl doesn't have a space for it. I have tying to find out what would work and I saw a switch work behind the brake pedal and can i just splice the wire from the pressure switch? And if so which switch would work. Thanks any help would help.
That's what I did, I made a bracket and mounted the button so it works with the brake pedal.. And yes the wires work the same
That could work, but not for sure what parts will mix and match for the brake light switch. Maybe be able to find an extra port on your distribution block? Maybe someone else has an idea.....
Try this-
I used a single pole switch, about 2 bucks from parts supply, took out the rubber stop on end of brake pedal arm, it screws right in that odd shaped hole.
In the picture is that a combo. Proportioning valve and metering valve in one.
It is a combination valve-
Metering - Pressure Differential - Proportioning
