I'm in search of a v8 (sbf) fan shroud for my 64 it has the original style radiator possibly the original.
Does anyone have info on refroduction, facsimile or an original?
I can fab one from aluminum but that's not what was done back in the day.
6t4 bolt
There are shrouds available for the 64 small block radiator because it uses the same radiator as a 66 Fairlane. They are plastic repos and run about $100. The place I saw them was from Mac's although I do not recommend you tell them you are using it on a 64.
I built a T-Bolt replica with a 427 FE and they listed shrouds for 63 and 64 Galaxie with big block (the same radiator the factory used in the T-Bolt) but I made the mistake of asking them what was the difference between the 63 shroud and the 64 shroud. Instead of answering my question they ask what I was going to use it on, when I told them they refused to sell me one because I was not using for the right application.
I think they are a bunch of dumb a-s h-les telling me what I could and could not bolt it onto.
I later found out that the only difference in the two years was the spacing of the mounting holes which would have not effected my use since I built a custom radiator for my car.
Good Luck
Mike
