I've looked high and low on this topic and there is a lot of info on this swap, however it's not what I'm looking for. I did the grenada disc swap. Everywhere I read said that you use the grenada outers. They don't fit the factory adjuster. What tie rods are you supposed to use? pns would be nice. I have called mustang Steve and I'm waiting on a call back. Any help is appreciated.
You'll probably have to change both inner/outers and the adjusting sleeve. That might be tricking depending on what a 64 used on the center link. Try the inner rod on the spindle to see how it fits before buying anything. 64 Fairlane, depending on engine was pretty small stuff. Actually early Mustang.
