Hello again Galaxie friends,As usual , I need your wisdom.
First of all, I'm having hood alignment issues, the back part of the hood does not close all the way when the hood closes on both sides.When you push down on it after the hood is closed, it goes into place a little better,but it won't go down on the initial slam of the hood. I greased the hinges,shot oil in the hinges,etc. but no help. What adjustment can I try ????
The trunk is out of whack also, it closes level near the rear window, but it won't close at the back of the car ! We have tried to adjust the latch inside the trunk which does move up and down, but then the latch on top in the trunk won't catch when we lower that latch pin on the bottom. Again ,HELP !
Unfortunately when my car was put back together by the previous owner, he did it in a hurry.The doors are out of line also. The doors are a 1/2" off at the door handle compared to the bottom of the door where it is in line.
SO, before I start messing with anything, I thought I would check with the experts.
Thanks for all the help folks !!! you have all been a great mentors on my new 64!
And to answer a previous question, the car is called "STELLA".....
Thanks,
Red
Thanks,
Red
