I have a 64 Galaxie and want to convert it from the factory 3 on the tree manual to an automatic column shift car.
What will I need to make this happen?
What type of transmission will I need that will bolt up to my 289 small block?
Do I need to replace the column or can I replace the 3 on the tree column collar with the automatic column collar and add the gear selector indicator? (I found those parts on the web and both were fairly inexpensive but don't know if the conversion is that simple)
Is there any cables or rods that I need to connect the shift lever on the column to the tranny?
I need someone with some knowledge about this to give me some advise. Please help!
