I'm in the process of rebuilding the front suspension on this 64 Gal. Im now at the stage of buttoning everything back up by installing the lower control arms. When taking them out and loosening the nut from the offset shaft, it too started to thread out. I was finally able to get the nut off but had to hand thread the offset shaft back in by hand. Finally my question: How tight do I need to tighten the offset shaft back in? Does the position of the offset shaft matter when tightening the lower control arm?
Thanks!
