1 - 12 of 12 Posts
I did a search on the forum & come up blank ...
I'm in search of a rubber mat - instead of carpet for my sedan.
Anyone have some direction??
Thanks.
6T4
ACC has the rubber mats. Check with any of the Fairlane suppliers that carry ACC
Discussion Starter · #3 · (Edited)
Thank you.
Your '64 is coming right along.
I'm almost done too.
Ended up with a 9.50 15 26" tall Hoosier on a steel wheel that I had to cut the center loose & reset offset. Probably can get a 10.00 withought an issue.
Need the mat to replace the very discolored carpet. Seats are ready to go in.
That's it ...
Discussion Starter · #8 ·
Thanks Jet - already have 1 coming from autokrafters.
Should be here next week.
Almost done & will post pix after I return from vintage drags on May 11 in Atlanta.
Anybody ever use them and do they fit? My 64's original rubber is shredded.
I bought a rubber carpet for a 66 F100 i was working on from LMC and the thing didn't even come close to fitting the simple contours of a 66 pickup floor. I won't waste the $200 if it's no better than a $10 flat piece of rubber from Home Depot
I have the rubber mat from ACC. I haven't installed it yet, but recently pulled it out of the box to lay it out. Both front and rear pieces have been molded to the floor. The kit also includes jute underlay. with a little work with a heat gun and some trimming the rubber mat should fit good.
Tom, you'll see how the mat turns out in the next couple months...
Discussion Starter · #12 ·
So I get my delivery from AutoKrafters today & guess what ????
Remember ACC says to me the day before I order from Autokrafters that they do not sell them ... a real live person on the phone told me this ...
Autocrafters drop shipped the rubber mat for my '64 sedan my rubber mat direct from ACC out of Alabama ... the same people I called days prior.
Go figure.
Why do companies do such stupid sh%t to the buying public?
Hopefully it'll warm up so I can lay it out so it'll easily drop in.
I'll do pix afterwards.
Paul
1 - 12 of 12 Posts
