Hi all,
So after a long day at the junk yard I returned home with my goodies. One of which is a rear sway bar off a 78 T-bird. So I crawled under my 66 and started looking, thinking, and I said to my self, "self...seems as though there are to options to mount this, but I do not feel comfortable enough to make that call. Better get some information first." So here I am.
So I took everything off the T-bird that was for the rear sway bar minus one end link, it was not leaving the car ( it broke). I have the mounts that go around the axle tube and one end link, and the bar too. My thoughs on mounting are listed below.
(A) To mount it I can box in the trailing arms(fits perfectly between them), drill a hole to mount it to them, and call it done. The bar will be secured to the axle tube as well using the parts from the T-bird.
Problems: Will there be enough freedom for movement of the rear axle, will it cause binding?
(B) Make mounts that bolt to the frame, at the rear crossmember thing, but I will need to make shakles between the frame mount and the sway bar to allow for movement of the axle up and down. I think if I fail to do that it will create a situation that causes binding for sure. It will also be secured to the axle tube using the mounts from the T-bird.
WHich options is best. Myabe one not listed. I know I can buy one, but where is the fun in just bolting it in. There need to be some movement, but not as much as a rock crawler. I dont know how much is needed.
If you have a photo of one on a 65-67 that would help a bunch.
thanks,
coal
thanks,
coal
