The underside of the frame rail on the passenger side is taking shape. I plan to add one more plate to it that will cover all the patches. I had to remove the box that the strut rod attached to because it was rotted out. The downside is that I lost one of the mounting points for the new sway bar, so I'll have to scab on a threaded plate later on. I'll also gusset the rail and core support to add back some of the structural strength.
The last couple of days have been really nice, so I opened the garage door and used the plasma cutter to remove the shock tower and a-arm mount from the driver side. When I did the passenger side, I set off the smoke alarms but all the smoke and stink went out the door this time. It's starting to look like the Coyote may fit in there after all.
