Can someone please explain the seam? At first I thought someone put a new panel over the rotted panel but I checked the passenger side and under the driver side and now I'm thinking that seam is stock. Is this correct? I'm also posting a pic of under the car where the panels meet and where there is a little square panel cut out of (not sure what that part is called). Is this little square panel stock also? Thank you in advance for any knowledge you can share.
