So, basically I bought myself a 1965 Ford Falcon Futura 4 Door for $1000, all original, but boy does she need some lovin' and I have no clue what to do. So here's the more noteable problems, my blinkers,gauges, and windshield wipers refuse to work now, when I first picked her up she ran great and everything was fine minus the front right drum cylinder was leaking but that was an easy replacement, after a week or so i would have to wiggle the ignition a little for everything to start working again, and then a week or so after that, bam, nothing worked. So I bought myself a new keyed ignition thinking that would solve the problem, and now I am having some serious trouble getting the entire switch system to stay in place and work correctly, would any of you gentlemen have any words of advice or guides to help me on this problem?
Second major problem, actually I should have put this at first because it is MAJOR. I am pretty sure my generator is shot because whenever I would park my car for more than say 30 minutes I would need to get a jump to start, I thought something was wrong with my battery or the wire's where on backwards, so I disconnected the battery, looked it over, and tried to reinstall it, upon connecting my positive the battery will start arching wildly, at first i thought it was normal so i just ratcheted it back into place, and as soon as i did that i noticed a nice trickle of smoke coming from where the generator is, upon noticeing that I immidiately remove my the positive and tried to find a short in the wiring that I could get to but that was to no avail. I bought a refurbished generator from autozone, but unluckily I cannot find any guides on how to replace it, do any of you have any suggestions or guides?
Thanks in advance for any help I recieve, as you can probably tell I am far from familiar in this area of expertise.
