I have a 1965 Galaxie 500 LTD in 99.9% factory condition with the 6-way front power bench seat that I've removed for repair.
In summary;1) What is the best mothed to check solenoid function? 2) How can I make seat driveshaft cables or find an affordable replacement?
In detail...
The front/back function works fine but the seatback recline and bench up/down didn't work. After disassembly and testing the braided driveshaft cables for those functions are completely broken. More importantly, when I hit the switch for the broken cables the shaft for those cables doesn't turn.
I believe I've narrowed this down to a solenoid issue where the seat adjusting regulator shaft isn't engaging the motor driven gear.
As far as I can tell all three gears turn together when the motor is engaged and the regulator shaft is pulled down to engage the teeth on the gear face. My first issue is that either these solenoid cylinders are broken or the shaft was seized in the bore. The motor engages correctly on all switches so I don't think it's a relay issue.
Secondly are the cables within the tubes. At a minimum two of them are sheared and need replacing. Unfortunately the few that I can find online are $$$ just for one. It seems as though switching to a more solid steel square profile shaft could be an option, otherwise I need to find a way to get a length of the braided style and figure out the method of squaring the ends. It'll need a good cleaning and some form of lubricant, I sure don't know what this old blue stuff is, maybe just regular grease with copper corrosion.
My 66 Fairlane and my 67 Cougar don't have power seats so this is a first for me. Still sorting out the vacuum actuated ventilation components on the Galaxie in the meantime.
In detail...
