Quick background - 65 Galaxie that I bought 6 yrs ago. No motor/trans and off the road for decades. There was evidence that someone ran over something. The drivers side front lower A-arm & strut(?) rod were bent. Replaced them. I have driven the car maybe 100 miles. I did have it put on a frame machine right after I bought it. The tech said that everything was ok.
Problem - I replaced the rear springs with another set(stock) and replaced all the bushing. When I went to reinstall the panhard bar, the only way to get it on was to jack the right side of the rear way up and let the left hang loose. It seemed a little odd but it was the 1st one that I have done. Now the rear end is offset about 1" + to the left side. My right side tire is jambed against the frame.
Possible cause? - Has to be accident?
Solution - Back to frame machine? or adjustable panhard?
Mark
Mark
