For 64 Furura & Comechero,
Thanks for the suggestion.
As for the splines on the Ranchero, they are indexed--that is there is one spline larger than the other splines on the shaft. The arm has to mate up with the shaft. So to rotate the arm on the shaft won't work. The motor arm in the picture is longer than mine. The motor arm I have is "too long" ( a short one) too far at park and the linkage won't reach without making the wipers pull up on the windshield about 2". By the way, all parts appear to be the original 1 speed parts.
Also, the Mustang motor is very noisy when mounted to the firewall frame and the noise resonates throughout the inside of the dash whe mounted. I don't know where to go & have looked for a rebuilder for these motors, but no luck. Chime in if you guys know some business who does it. Have 3 & all are noisy or don't work.
Plan "B" is to use a motor/switch combo from a 74-78 or so F100. It mounts by changing the grommets on the bracket to line up with the motor case, but have one question to those who have done this swap" Is the motor shaft when operating suppose to rotate a full 360 degrees? It is a rebuilt one from Rockauto. I checked the applications & the motor covers a few years. The switch is ok to mount like the motor, but I checked the motor first & saw this happening. Any thoughts as to why the motor rotates a full circle (busted) instead of the 90 degree or so swipe?
I notice that the gear case is smaller than the Mustang 2 speed. Looked inside the truck motor gear case & there are fewer gears compared to the Mustang. It also has a intermitent control and in that mode, the motor rotates a full 360, pauses and goes on etc. But when the power is off, the motor does "Park" in the same place. I haven't gone further to install to see if the linkage lines up. But if you guys have done the 74-79 or so motor swipe, let me know so about the motor rotation if I need to return the motor to Rockauto for a replacement part. Sorry its long, but wanted to give you guys details.
