So does anyone have or know where to get a neutral safety switch for a 65 column shifter
By 'fiddle' do you mean 'wiggle' the key switch? If so I would think its the ignition switch and NOT the N/S switch. That usually intails moving the shifter to the "sweet" spot....if I fiddle with the switch it starts right up so not sure if this is a common problem or it just needs to be replaced
