66 Galaxie Firewall/Cowl Panel Insulation Repair/Replacement.
550 Views 6 Replies 3 Participants Last post by  extech
4
So here is the old firewall or cowl panel insulation from my 66 Custom 500. It’s broken in several places and a piece or two might be missing. Have the guys that have had this out encountered this problem? Should I try to fix it ??? And reuse it or do the adhesive mass panels and insulation materials available aftermarket good enough to do the job? I counted 8 retaining pin holes on the insulation that look like they go through the insulation and lock into the firewall. I could probably find small plastic plugs to fill the holes in the firewall. There are so many there already!
Grey Rectangle Font Tints and shades Gas
Sleeve Hood Grey Automotive exterior Bumper
Brown Wood Rectangle Road surface Brick
Automotive tire Hood Automotive design Window Motor vehicle
See less See more
that stuff was available new for my 63. try ecklers
Extech,
Thanks for the tip. Ecklers does have a listing for this! I’m definitely considering buying one. We’re you happy with the quality of it?
Extech,
Font Screenshot Fashion accessory Rock Rectangle
See less See more
I had a couple tears in mine that I was able to repair with weatherstrip adhesive. Yours looks rough enough that I don't think I would try to reuse it. Go with the aftermarket one...Luckily this is not something you'll likely ever see.
sorry for repost. mine wasn't plastic. same as origional. putting the retainer pins in was a bear
