1 - 8 of 8 Posts
I know this is a Falcon Forum, but I figure someone would have info on it's ugly half sister. A friend of mine is looking to put a disc brake set-up in a 1966 Mercury Comet Caliente. Is there a later model cheap swap?
I know the full size Galaxie in 1966 can use the 77-79 T-bird set-up with almost no modification.
Is there such a thing for the 66 Mercury Comet? The car is a 289,automatic if that makes a difference.
Thanks,
Vince
On my '68 Falcon I used a '69 Torino power brake setup. I would think that the '66 to '70 Falcon would be adaptable also.
I would thing that the '67 & up Mustang, Fairlane, or Torino systems should fit on the Comet.
TJ in GB
TJ in GB
On my '68 Falcon I used a '69 Torino power disc brake setup. I would think that the '66 to '70 Falcon would be adaptable also.
TJ in GB
The trusty Granada setup will fit. I just converted my 64 Falcon and it worked great. As long as your upper ball joint has 4 mounting rivets it will accept the Granada spindle. You just have to reroute the front brake lines to a Granada front flex hose setup. Good luck.
You will also need a different tie rod end which I sourced from Mustangs plus. A good parts counterman can also source these if you give him all the specs of the old tre.
Thanks,
Vince
are you talking front or rear discs?>
if front yes the mustang discs are a bolt on no brainer.
there are plenty of kit forms to do it also.
the rear is almost just as easy, they make bolt ons, and or a bracket that welds to the housing, and then everything bolts on
1 - 8 of 8 Posts
