Hi All. I am rebuilding the interior of my 66 stang right now. I tried to wire up the cluster and everything works except the fuel and oil pressure gauges. The wiring is correct and was working one month ago when I took everything apart. Could this just be the voltage regulator? I cannot think of anything else. Thanks
geoff
geoff
It's likely yours and the OP from 15 years ago both have problems with the voltage regulator for the gauges, which is different from the regulator for the generator/alternator. Try to find a wiring diagram for your car. The instrument voltage regulator was mechanical and reduced the 12-14 volt battery voltage to 5-6 volts I believe. Pretty sure there are solid state replacements available now.
Pat
geoff
