Does anyone make a set of solid engine mounts for the early style 1966 mustang engine mounts?
If not do you know anyone who makes an engine torque strap/link. I need to keep my 302 from rolling/twisting.
I've seen the article on the home made one, but wanted somthing a little cleaner looking.
Thanks for the help/info.
I am using a bolt through the motor mount. Works fine for me.
1966 Stang Coupe Org. 6 cyl. 351w,Sealed Power Hypers, ARP bolts,Total Seal rings,Eagle H-beams rods,Balanced,Hedman long tubes, Pro Comp 2.05/1.60 Heads, Shaft roller Rockers, Victor Jr intake, Holley 750 DP, Ed Nix Custom .600/.600 254/258 @.050 Solid Cam, Crane solid roller lifters,Richmond 4.11, Strange mini spool, Modified C4, 3500 stall, ******* Transbrake, B&M Hammer shifter, Shelby lowered, Pro Comp 6Al system. Mickey Thompson 275/50 Et Street Drag radials.
<font size=-1>[ This Message was edited by: forthman on 8/6/06 6:42am ]</font>
