1 - 20 of 203 Posts
Loaded up and headed for roll cage and subframe
[/URL][/img]
[/URL][/img]Its a little frosty this morning!
[/URL][/img]
Discussion Starter #2
[/URL][/img]
[/URL][/img]
[/URL][/img]Rod & Custom Subframe setup
[/URL][/img]
[/URL][/img]10 Point cage install
[/URL][/img]
[/URL][/img]
[/URL][/img]
Off to the media blaster.
[/URL][/img]
[/URL][/img]
Almost ready to undergo blasting.
[/URL][/img]
Ahh, all paint gone and almost no rust!!
[/URL][/img]
[/URL][/img]
Discussion Starter #4
At the paint shop now, have new lower quarters for the rear and patch panels for the front fenders, will post pix when I have them.
Sweet! Will those side bars pass tech like that, or are you just going Pro Street?
Discussion Starter #7
With the seat all the way back it will pass, cage should cert for 8.50's
Just went though the same with mine bill,how are the wheel wells? we had to make about 2" to meet the quarter shes coming along nice keep the pics coming...ED
Discussion Starter #10
A few more from the body shop
Here you can see a new outer wheel house being made that has lots of clearance for a big tire.
A closer look
You can see one of the front fenders already patched. You can also see the forward bars of the cage and the dash bar, very pleased with how it fits. Once it is painted to match the dash and doors it will blend right in.
Trunk view to the outside, hope to not see this again!
Discussion Starter #11
Got these engraved for a Christmas gift, great girlfriend! Should look good with fresh paint, got the idea from the new GT 500 ones.
Discussion Starter #12
Progress today, right quarter back on with new outer wheelhouse
View from trunk looking forward
Looking back from passenger seat area. More room for larger tire.
Your moving right along nice job.is the roll bar a kit? I like the way it tucks in are you doing the bodywork or is it at a shop? Working on mine weekends should have in paint soon,good luck and keep the pics coming.
Discussion Starter #14
The roll bar was a kit but we modified it because it didn't fit the way I wanted. The car is at a shop, don't have the skill or patience for body work. I will be handling all the reassembly once they are done, hopefully first of March.
Discussion Starter #15
Quarters on and new outer wheel houses, lots of extra room. The rear fender lips are also rolled with the wheel house, very rigid and extra room.
Discussion Starter #17
New tunnel plate, it is removable for trans access. The floor shifter (Crites part) is visible in the background
Hole for new wiring routing to not be visible from under the hood
Revised visor mount, old one was not accessible due to the cage
Lonely waiting for final body work then primer. Unfortunately because of the cold weather the primer will have to cure for 2 weeks before final blocking and paint.
Discussion Starter #20
I will be running the same 351C set up that came out, just freshening the short block as the heads were done when I switched to a roller cam. Just picked up the block and need to clean it and reassemble.
QUESTION- how do you guys clean a block fresh from the machine shop?
Planning to scrub with brushes and hot soapy water then oil down surfaces.
1 - 20 of 203 Posts
