today I removed the engine installed in project 65 coupe.
was a 6 hole bellhousing & flywheel said "67 289" in crayon.
(salvage yard markings). I was losing coolant somewhere out
the back of block, hav'nt figured that out yet BUT coolant did
readily flow out flywheel bolt holes, is this normal ? I'm thinking something has cracked inside. the engine did have all
frost plugs pushed out, replaced those BUT still leaked coolant.
so...............should coolant be coming out flywheel bolt holes?
(flywheel off, first bolt out = poured coolant)
