1 - 12 of 12 Posts
I ordered a torque converter for my Cruis-O with a 2200 rpm stall on Friday. The guy said he had a valve body from a 67 Cruis-O that would allow me to shift manually from 1 to 2 to D. Something about green dot's or green somethings. Does anyone know if that valve body will work in a 64 case? Thanks in advance.
Discussion Starter · #2 ·
TTT
Wow!!! Did I stump the wizard or what with his question? Can't believe no replies yet.
All I know is that in 64, the pattern was P R N white-dot green-dot L
In 67 it changed to P R N D 2 1
Assuming the trans guy knows what he's talking about , the 67 VB in the 64 case would change your trans to white-dot=D, green dot-equals-2, L=1
I don't have any dots. That's what is weird!! I have P R N D2 D1 1. The car has a floor shifter though so that may be the difference in labeling.
Thanks. I hope to actually get one that's not a car show and that actually shows how much lower she sits. Maybe this weekend. Gotta be getting close to fall/winter down there. How's things going?
Discussion Starter · #8 ·
Jay at Broader Performance called and said that the box was mislabled and the valve body in the box is actually for an FMX so I guess this thread was all for not. Anybody have a 64 cruis-o valve body for sale? I start a new post too but thought I could start here.
· Administrator
But isn't an FMX also the standard shift pattern? Not the green dot. Or is it that it could be either shift pattern still. I have an MX I got at the junk yard and using in my car now but have a "green dot" I want to put in eventually.
I get so confused on these trans labels, FMX, MX etc.
Discussion Starter · #10 ·
You and me both! I don't know if a Cruis-O is considered an MX or not. Broader Performance said that the difference in valve bodies is that there is no rear port in the valve body for an FMX. Sure wish I had the dough left to put in a C-6 though.
Well, regardless of the labels, in any '58-'66 Ford auto, after N
comes D2, then D, then low. D2 allows second gear starts, just as "2" in a 67-up does. The difference is that in D2, the trans will eventually upshift to 3rd, it can't be held in second, unlike the 67 -up "SelectShift", which can be held in 2nd until the cows come home . Both types , however, allow for LOW (1st) to be held indefinitely
Discussion Starter · #12 ·
Select shift is what I was after. Figured it would be better for the occasional impromptu street race.
1 - 12 of 12 Posts
