1 - 8 of 8 Posts
I cant get search to find anything.
What is the width of my 67 falcon rear end axle flange to axle flange??
59.25 is correct - 54.25 housing plus 2.5" each side for brakes. NOTE - the difference between the listed cars will be in the leaf pad location: Falcon/Fairlane will be 44" OC, Mustang is 43" OC.
Cool thanks,
I just ordered a 9 inch that is 56" from axle to axle. With my 3.75" wheel offset I think it will be just about perfect for a set of 10.5" slicks.
I had mine made 54", making it 59" at the axles. I can get a 28- 10.5 x 15 MT on a 4.5" backspace wheel under the car with a very thin 3/16" spacer to keep the tire off the leaf springs.
ckelly where did you get your caltracs bars and did you have to modify them to fit the 9 inch ?
1 - 8 of 8 Posts
