First-time post here, and hopefully I can get some ideas on a minor question: is there a simple way to adjust rear ride height?
I have a 67 Galaxie 500 two-door hardtop with the 390. This was the car I learned how to drive in and was a gift from my grandmother when I turned 16. I drove it all through high school and now I finally have it in my name after my father's stewardship since then. I need to correct many ills with the car starting with the suspension. I am also learning about the car mechanically as I go, as I have not worked on it since a teenager.
The issue is that for many years, it has had an uneven squat in the rear with the driver's side about 1 1/2" lower than the passenger's side. I like a slight rake or an at-least neutral stance. Eaton said that the factory setting on this car was a 1" lower ride height in the rear to begin with, then they tend to often sag over time, not necessarily evenly.
So, I started with installing a set of 1" heavy-duty rear lift springs from Eaton with new KYB shocks. The overall rear height is now much better but I still have about a 1" lower height on the driver's side.
The fore-to-aft control arm on the passenger's side has what looks like an eccentric bolt with the head pointing outboard - see the dead center of the attached pic back behind the shock. Can that bolt be used to adjust rear height? It looks like it might also introduce fore-and-aft movement of the axle if turned, which could be a problem.
Caveats:
-We've known the history of this car since new. It's never been in a wreck or other event that would create these issues.
-I recognize that uneven wear or other issues with the front springs/suspension could be to blame, introducing diagonal ride height effects. Many might say you need to replace all four corners at once to know what's up. I may be doing an engine swap and/or installing an entirely different front steering and suspension set-up. So, I am holding off on investing in front suspension components for the moment.
Thanks all!
Caveats:
Thanks all!
