First time poster here. Does anyone have any idea on how to remove the front frame mounts. I can't see any way to access the bolt heads inside the torque box. Any help would be great from someone with a clue on this one.
The access to the front bolts are is thru an opening in the body mount from the top/firewall side. The problem is getting them loose without breaking the little captured nuts loose on the other end holding the studs to the frame.
Welcome, and hope this helped.
Jim
