i've heard that you can run a bolt thru the stock rubber motor mounts to make them into a torque strap. could anyone show where to do this for a 1967 galaxie FE mount?
thx. for your time.
What you do is to drill thru the mount, run a 3/8 carriage bolt thru it and tighten with nut on the back. Weld nut to bolt and back of mount. Grind a little off top of carriage bolt to flatten it, so it will still sit down on perch to put the long bolt thru.
www.fordautowrecking.com
Dane V
