1 - 8 of 8 Posts
just picked up a 67 mustang coupe with great body for really cheap. however, cranks but wont start, primed the carb and im getting spark. decided to check compression and...
cylinder 1: 90psi
cylinder 2: 80psi
cylinder 3: 0psi
cylinder 4: 120psi
cylinder 5: 0psi
cylinder 6: didnt bother checking
does a head gasket seem like a probable cause, or could it be something else? would I be better off troubleshooting or should I just get one from a wrecker?
Thank you for all the help you guys have given me!
-Tony
You probably have a few burned exh valves just like pedal said. I used to have a six with same prob. replaced the exh valves and had hardened seats put in and it ran smooth and great afterwards!!!
Im located in roseville, california. today i poured a little marvel mystery oil in each cylinder and cranked it a little. did nothing for compression so hopefully the problem is in the head. i dont wanna pull it off until I have the money to get it redone so it doesn't get dirty. When I do pull it off what am I going to be looking for? Never really messed with engine internals before so is there going to be anything very obvious? Thank you for all your quick replies!
-Tony
HI TONY
when you pull the valve cover off roll the motor over and watch the rockers just to make sure its not a rocker or something. Look for broken springs on the valves and such. especualy 3 and 5. once the head is off look at the valves you well probuly see a hole burnt into the 3 and 5 valves with 0 compression it should be obvious but may not.. OH check the top of the pistons as well for holes or broken rings.
tim
ALWAYS THE RED NECK WAY
61 Merc. Comet, 200 3spd.
1964 International 4door, short box W/466
<font size=-1>[ This Message was edited by: pedal2themetal45 on 4/7/06 11:10pm ]</font>
Is the engine running, at all?
I find it hard to understand 2 cylinders showing 0, zero compression and the engine still running. Essentially,with zero compression on those two, you have a 4-cyl engine. I would expect the engine to shudder, pop, shake and have all manner of crap spitting out of the tail pipe.
If the valve head was there at all, I would expect some compression...at least 20, 30 lbs...something.
1 - 8 of 8 Posts
