I have a 68 F100 "Ranger" I bought for parts for my other 68 F100 w/ I6.
The Local Pick and pull will give me around $380 if I drive it in.
Trying to decide if I should part it out or junk it.
It has a 2BBL 360 V* (runs but with a lifter tick).
Power steering box leeks like a "siv" or it might be a good utility truck as. I rebuilt the carb, put a new water pum and then a power steering pump before I found the deal breaker for me, of the power steering box leak.
Could not pile more money into it.
It has:
A working C6 auto
Huge radiator that has a small leak around the cap area. Most likely just needs a clean up for $60.
Dealer add on Air Conditioning unit.
Nice gauges and knobs and such.
Extra gas tanks
Fenders with no dents and only surface rust.
I am keeping the hood.
Good trim chrome all around for a "Ranger Truck" with logos
I kept the bumpers.
I have a good front bumper because I traded mine for the original ( it was thicker).
Good rearend. I think it is a nine inch on that truck.
Suspension, drive shat all good.
Sooo, is it worth the effort to part it out?
It is easy to take it to pick and pull.
I am in San Jose, CA
any thoughts?
worth it?
I would, but I've got a shop and I don't mind the labor.
If you part it out, there is no reason you couldn't make more than $380.
How much more depends on how good any of the parts are.
if you decide to part it out ...
i would be interested in the c6 ,whole set up from the flex plate to the driveshaft yolk...
how much do you want for it??
im located in san francisco....not to far from you.....;)
A 68 should have a 9" unless it is one of the rare Dana's. I think you would make more parting it out
clint
