'68 Futura 289 4sp
I'm trying to locate the flasher unit for the four way flashers. Can someone tell me where it is located under the dash? Pic of where it is? Thanks
Sorry no pics. From the shop manual..."The turn indicator flasher is located in the back of the instrument panel. The emergency warning flasher is located on the right side of the upper steering column hub."
'68 Futura 289 4sp
for some reason my ride has the four way with the ground wire. I just plugged in a regular flasher they work. Thanks for everyone's help
